Automatically export the heat flux to a CSV file |
Kazuto Nakagawa
Rep Power: 0 ![]() |
Hi
I am using ANSYS Fluent and currently reviewing the analysis results in CFD-Post. The analysis involves a cylindrical geometry, and I am interested in calculating the wall heat flux. Specifically, I want to compute the heat flux over the entire surface area, rather than at point. I have found a method to export the wall heat flux to a CSV file. However, this can only be done for each time step individually. I am computing the heat flux over nearly 200 time steps, and manually exporting all of them is not feasible. Is there a way to automatically export the heat flux to a CSV file for each time step in ANSYS version 2022R1? I read the Fluent Use's Guide 14.2.3.6 Exporting heat flux data and use this way to export heat flux, but this is only export each time step individually. Thank you in advance. |
fluent, heat flux. |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
