Visualizing Pressure Change in a Pipeline System |
June 26, 2024, 09:05 |
Vinay
Rep Power: 2 |
Hello everyone,
I'm working on a project where I need to plot the change of pressure from the inlet of my geometry to the outlet to visualize the change in gauge pressure as it traverses through the pipe segment. Please refer to the images added to this post for better understanding. I have a couple of questions regarding this: Background:
Questions:
Images for Reference: Piping_segment_sketch.jpg Thanks in advance for your help! Last edited by ElHombreMagnifico_CFD; June 27, 2024 at 00:36. |
June 27, 2024, 02:11 |
Marcin
Rep Power: 13 |
Here's how to address your questions about plotting pressure change and determining pressure drop in ANSYS Fluent:
Plotting Pressure Change: * Surface Reports: Utilize Surface Reports in ANSYS Fluent to obtain average pressure values at the inlet and outlet faces. * Create a Derived Quantity: Define a derived quantity in Fluent that subtracts the inlet average pressure from the outlet average pressure. This will represent the pressure change across the pipe segment. * Line Plot: Generate a line plot using the derived quantity to visualize the pressure change along the flow path. You can create a line intersecting the inlet and outlet faces to extract pressure data along that path. Determining Pressure Drop Across T-Junction: * Surface Reports: Similar to above, use Surface Reports to obtain average static pressure values at the inlet and outlet of the T-junction you're interested in. * Pressure Drop Calculation: Subtract the outlet's average static pressure from the inlet's average static pressure to determine the pressure drop across the T-junction. * Loss Coefficient: Static pressure is recommended for calculating pressure drop across pipe fittings like T-junctions to determine the associated loss coefficient. This is because static pressure represents the usable energy in the fluid stream, and the loss coefficient accounts for energy dissipation due to the fitting. Additional Tips: * Ensure you're capturing pressure data at the appropriate locations (center of inlet/outlet faces) for accurate results. * Consider using path functions in Fluent to extract pressure data along specific flow paths within the pipe segment. For more in-depth information, refer to the ANSYS Fluent documentation on surface reports, derived quantities, and pressure monitors. MORE AT LINK BELOW https://howtooansys.blogspot.com/202...re-change.html
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
June 27, 2024, 02:29 |
RE: Visualizing Pressure Change in a Pipeline System
Vinay
Rep Power: 2 |
Hi Marcin,
Thank you so much for your detailed explanation! Your instructions on using Surface Reports, creating a Derived Quantity, and generating a Line Plot in ANSYS Fluent are very clear and helpful. I do have a couple of follow-up questions regarding the line creation for plotting the pressure change:
Thanks again for your help! |
June 27, 2024, 09:48 |
Marcin
Rep Power: 13 |
You're right that creating a single line with two points in Fluent limits you to data extraction along that specific path. To capture data across the entire axial flow path (centerline), you can create a rake entity in Fluent. Here's a general guideline:
* Go to the Operate menu and select Lines/Rakes. * Choose ** Rake**. * Define the starting and ending points of your rake line along the centerline. * Set the number of points within the rake line. This defines the data resolution along the centerline. Fluent will create a series of points along the centerline, allowing you to extract data and plot it versus the rake line's axial distance.
July 5, 2024, 14:13 |
Solution
#5 | |
Vinay
Rep Power: 2 |
fitting, plot, pressure drop, t-junction |
BCs for extraction system - Velocity or pressure? | THK | FLUENT | 0 | May 31, 2016 08:02 |
CFX Solver stopped with error when requested for backup during solver running | Mfaizan | CFX | 40 | May 13, 2016 06:50 |
Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 18:57 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
