Applying spring force onto solid PCM while melting |
June 25, 2024, 23:57 |
Tapasvi Bhatt
I am simulating a scenario involving a 2D PCM rectangular domain where the bottom side is heated. The bottom wall contains pores to allow liquid PCM to seep out. Additionally, a spring is attached from the top, with parameters: spring constant and natural length (which equals the height of the rectangular domain). Initially, at , the spring is fully compressed to a length , exerting a force onto the solid PCM. As time progresses to , the solid PCM displaces by , altering the force to . This force diminishes to zero as the entire PCM melts and the spring returns to its natural length.
I am familiar with simulating PCM melting using ANSYS Fluent. However, I am seeking guidance on how to incorporate this spring force into the model using Fluent alone. Someone suggested that this might require addressing it as a Fluid-Structure Interaction (FSI) problem involving Fluent + Structural. Nevertheless, I believe there should be a method to accomplish this within Fluent itself. My primary challenge lies in how to integrate this varying force and how to define it as a function of the solid PCM displacement. The attached figure provides visual clarity on the setup. I appreciate any advice or insights on implementing this spring force into my Fluent simulation effectively. Thank you! Image available at: https://entuedu-my.sharepoint.com/:i...7dUzbVIYx03zJg Last edited by bhatt01tapasvi; June 26, 2024 at 00:07. Reason: latex mistakes I commited and image not visible. |
force, melting, pcm, springs |
Pcm melting, multiphase | mehran-b | FLUENT | 3 | January 8, 2021 06:48 |
melting + vof modeeling for PCM in air | taw | FLUENT | 2 | August 24, 2018 00:21 |
Applying drag force in the fluid model | CanadaFlanker | CFX | 7 | May 5, 2014 23:13 |
Simulate melting process of solid aluminium in liquid Titanium | anirudster | CFX | 8 | March 21, 2014 09:20 |
Solid Object Melting in Flow-3D | tgomm | FLOW-3D | 2 | September 1, 2011 08:00 |
