June 18, 2024, 07:34 |
Pressure Based vs Density Based Solvers
Bran
Rep Power: 2 |
I have to model jet flow with a mach between 0.325 - 1.054. I am not sure whether to use the pressure based or density based solver .
Additionally I have been given exhaust velocity and temperature ( which can be specified in velocity inlet ) but also gamma equivalent, total pressure and total temperature values. I am not sure on where to specify these values, any help will be greatly appreciated. |
June 18, 2024, 10:03 |
Stuart
Rep Power: 26 |
Why not run a simulation with each solver and see how the results differ.
June 19, 2024, 16:42 |
Lorenzo Galieti
Rep Power: 12 |
pressure based solver is ok for these low machs and it has more features than density based solver. go for pressure solver
June 20, 2024, 09:10 |
Marcin
Rep Power: 13 |
Here you are (below) when to use each solver and examples to use in case studies
https://howtooansys.blogspot.com/202...olver-and.html
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
Pressure based coupled solver for internal supersonic flow | erkampasha | Main CFD Forum | 1 | December 7, 2022 07:07 |
Density or Pressure based solver | Achu | FLUENT | 1 | April 27, 2018 05:34 |
Pressure based vs density based solver | newbie384 | FLUENT | 2 | July 5, 2013 03:04 |
pressure correction scheme vs density based scheme | PCFD | Main CFD Forum | 0 | May 18, 2009 16:57 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
