Natural convection boundary condition
Old   June 15, 2024, 03:40
Question Natural convection boundary condition
Pepsi3892
Pepsi is on a distinguished road
Hello, I'm new to ANSYS Fluent and I'm trying to model natural convection. My setup involves a heated square box with a circular opening at the top. The box is heated to 50°C, while the surrounding environment is at 23°C. I've filled the box with air, but I'm unsure about the appropriate boundary condition to ensure that the heated air inside naturally exits through the circular opening at the top.
I'm considering using a pressure outlet at the box opening, but I'm unsure if this is the correct approach given that there is no inlet. Any suggestions or insights would be greatly appreciated. Thank you!
Pepsi is offline   Reply With Quote
Old   June 16, 2024, 07:57
Svetlana Tkachenko
Svetlana is on a distinguished road
There are two options
1. Use a cylindrical domain syrrounding the heated box. The pressure-outlet BC on its top and veryical boundaries allows backflow. Cylinder needs to be sufficiently large. (this can be done as 2D test if setup with cyclic symmetry)
2. Use a rectangular domain similar to a wind tunnel and set a low inlet speed. This may make the solver more stable. Experiment with 0.1 m/s, 0.01 m/s etc as the speed and try to reach a point when your result is not that affected by the further reductions in the speed anymore. (this test can be done in 2D, though results will not be realistic, they will allow you to assess the speed required. then proceed to 3D simulation)
Svetlana is offline   Reply With Quote
Old   June 16, 2024, 10:47
Pepsi3892
Hi! Thank you for your reply! I'm curious, would it be possible to add a pressure outlet at the opening instead? I'm wondering if that approach would still simulate natural convection.
Old   June 16, 2024, 13:00
Svetlana Tkachenko
just modeling the box and no adjacent air may be insufficient as this does not accurately represent the pressure distribution. i might suggest trying two simulations with only the box in one and the box with additional included air in the other, and comparing the results: my expectation is that the results will be different.
Old   June 16, 2024, 13:54
Pepsi3892
Alright! I'll give it a try. Thank you!!
Old   June 17, 2024, 03:26
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
Remember to set boundary conditions for natural convection with energy balance
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD)
https://howtooansys.blogspot.com/
Martin_Sz is offline   Reply With Quote
air flow analysis, cfd - post, natural convection bcs, natural convection flow, thermal analysis
Boundary Condition on farfield for natural convection fxzf OpenFOAM Running, Solving & CFD 0 March 1, 2022 04:49
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
natural convection boundary condition thomasyangfly FLOW-3D 3 September 11, 2012 11:14
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
