Dpm-vof bubble rising
Old   June 13, 2024, 21:47
Smile Dpm-vof bubble rising
Alejandro
Labsim is on a distinguished road
I have a problem in a simulation in which I use a vof-dpm coupling. I have a bubble that rises through a phase of the vof and reaches the surface, I use a udf that expands the bubble based on the y coordinate of the particle, but at the same time Getting to the top of the primary phase spreads me out too much.
Labsim is offline   Reply With Quote
Old   June 14, 2024, 05:29
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
try to simplify phenomenas , try make simple vof model with implicit solver
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD)
https://howtooansys.blogspot.com/
Martin_Sz is offline   Reply With Quote
Old   June 14, 2024, 09:45
Alejandro
Hello Martin
I already tried what you mention, I am running the case in a transient state, with energy equation, and with drag force, gravity, pressure gradient and for the dpm-vof coupling I am using two-way coupling.
The thing is that I have a case without bubble expansion and in that case the phase is not affected or disturbed, by adding the expansion the results that I should obtain should not be such a large dispersion (the continuous phase is dispersed as columns)
Bubble rising with VOF anzel87 Fluent Multiphase 1 September 14, 2017 08:35
rising bubble vof simulation in fluent vinita123 FLUENT 0 December 21, 2015 08:49
rising bubble vof simulation in fluent vinita123 Main CFD Forum 2 December 21, 2015 08:40
Conditions to be applied in vof csf bubble rising simulations in fluent MANOJ SS FLUENT 0 June 11, 2015 07:27
VOF single bubble rising velocity! Lincoln Main CFD Forum 3 April 10, 2012 11:04
