DP Pham
Rep Power: 2 ![]() |
Dear all,
I am now doing heat transfer simulation, and what I would like to do is creating the domain into 2 regions, the upper region is the gas block and the down region is the fluid block. The fluid block will import from STL file. Thus, how can I indicate that STL is fluid region. Thanks all. |
fluent, heat transfer, stl |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
