Juan
Rep Power: 0 ![]() |
Hi!
A did a simulation in Fluent about a straight pipe with a velocity profile as inlet = 0.05 m/s as maximum velocity, and pressure outlet = 0 at Outlet. The fluid is water included in Fluent database. Using the Darcy equation: DeltaP = rho * f * L * V^2 / D where Re = 498 f = 64 / Re = 0.128 I get DeltaP = 3.2 Pa (same as calculator online). The problem is that I get 1.6 Pa in Fluent. I have used Laminar flow, k-w SST and k-e realizable. All of them obtain the same value and mass flow net is equal to e-11. I had change the mesh and I did refinement but value does not change. Residuals go below 1e-6. What am I missing? The pipe has dimensions: Long = 200mm Diameter = 10mm |
#2 | |
Kareem
Rep Power: 3 ![]() |
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
Juan
In the inlet I have applied a name expression:
f(r) = Umax * ( 1 - (r/R)**2) Where Umax is the velocity 0.05 m/s, r is defined as sqrt(z**2 + x**2) and R = D/2. Pipe is along Y axis. This function I understand is for a developed laminar flow so I can use Darcy equation, isn’t it? Edit: if I use the mean velocity = 0.025 m/s I get DeltaP = 1.6 Pa which is the value obtained in Fluent. So mean velocity is needed in equation right? Last edited by Xatkor; June 5, 2024 at 05:30. |
fluent, missmatch, theorical solution, wrong value |
Discrepancy between Oka erosion formula presented by source and Fluent | Tonika | FLUENT | 0 | November 4, 2023 19:48 |
What should we pay attention to in the application of similarity theory with Fluent | Huo zero | FLUENT | 1 | March 27, 2018 18:38 |
FLUENT Theory Guide missing information | PedFr0 | FLUENT | 0 | April 24, 2014 05:18 |
Spalart-Allmaras model in Ansys Fluent 12.0 theory guide | macfly | FLUENT | 0 | February 7, 2010 17:03 |
kinetic theory in Fluent | Tschumperle Denis | FLUENT | 0 | October 17, 2000 09:48 |
