How to Eliminate Materials in Fluent
Old   May 23, 2024, 05:37
Default How to Eliminate Materials in Fluent
arjun
arjunchy71 is on a distinguished road
In Fluent,When i am going to add fluid and solid that time i found air and aluminum as a default and I am unable to remove both.
I wanna add MRF as a fluid and Steel as solid. How can i remove default materials to run my simulation perfectly?
Thank You in Advance
arjunchy71 is offline   Reply With Quote
Old   June 6, 2024, 02:14
Post How to Eliminate Materials in Fluent
Kadari Mahesh
MAHESH9966 is on a distinguished road
Dear arjun,
If you want to eliminate the default materials in the fluent,Actually air is applied automatically to all fluid cell zones & aluminum for all solid cell zones. so u have to assign the required material to respective cell zones so that none of the cell zones have material assigned with air & aluminum. Now u can delete the unassigned materials from fluent.
If you want to know how to assign new materials,
First u need to add the required materials using the fluent material data base or else u can create the new material by entering the required material properties with appropriate name.Then assign the actual materials to the fluid and solid .
If you have any query please feel free to ask in DM i will try my level best to help you out thank you,
All the best
MAHESH9966 is offline   Reply With Quote
Old   June 6, 2024, 05:39
arjun
Originally Posted by MAHESH9966 View Post
Dear arjun,
All the best
Thank You for your kind help.
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 13:16
Anslysis of Trombe Wall with Phase change materials in ansys fluent StefanosPur FLUENT 0 April 11, 2022 13:55
Fluent simulation with rotating wheels of different materials enigma6666 FLUENT 0 August 14, 2011 20:03
please help: very important. if fluent may utilise several materials ?????? bounhh FLUENT 2 May 30, 2011 01:53
fluent may utilise several materials ?????? bounhh Fluent UDF and Scheme Programming 1 May 28, 2011 03:25
