May 16, 2024, 07:54 |
Fluent 6DOF solver
CFD
Rep Power: 4 |
I have a question regarding the Ansys dynamic mesh- one degree of freedom spring connection. When applying the 1dof spring connection, i could not find a way to put a damping coefficient through GUI and also could not find it through udfs. I have read the Fluent manual but no luck.
Could you please tell me, if its possible or not. I am simulating a blade which is made up of two zones rotating about 0 0 and at the same time, i want a part of the blade to pitch about its center of gravity through a torsional spring connection with certain K. Is it possible to do it in 2D? |
6dof solver, damper, dynamic mesh, fluent - udf |
Selection of solver in ANSYS Fluent for given mach number | Ankit Patel | FLUENT | 9 | January 29, 2021 05:44 |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 16:44 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
6DOF solver (buoyancy and hydrostatic force) | ZacHillAdl | Fluent UDF and Scheme Programming | 2 | March 27, 2017 16:20 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 23:58 |
