May 16, 2024, 02:32 |
CFD analysis on Fixed wing VTOL.
bharath L
I'm encountering an issue with my CFD analysis on a Fixed-wing VTOL with a pusher propeller. Specifically, I'm trying to understand the impact of the pusher propeller on the airflow around the rear wing. The rotor domain within the outer domain is mistakenly identified as walls, which I suspect is causing inaccuracies in my lift and drag calculations compared to XFLR results. Despite achieving convergence after over 7000 iterations in ANSYS FLUENT, the problem persists. If anyone has experience with this type of issue, your insights would be greatly appreciated. Thank you.
cfd, fixed wing vtol, fluent, uav vtol |
3D wing Cfd analysis in batch mode | aek16 | Main CFD Forum | 1 | April 9, 2016 12:14 |
Delta wing cfd | H_R | FLUENT | 16 | September 19, 2013 05:41 |
[Other] Morphing wing cfd analysis in transition | rekfuh | ANSYS Meshing & Geometry | 0 | June 6, 2012 10:22 |
FDM vs FVM vs FEM in CFD analysis | ck5285 | FLOW-3D | 1 | September 1, 2009 11:51 |
I want to find overall solution about wing cfd | moons2001 | FLUENT | 0 | August 27, 2009 02:12 |
