The secondary phase cannot flow within the primary phase
Old   May 12, 2024, 21:45
Default The secondary phase cannot flow within the primary phase
Ghinna Nur Akram
gnakrammm is on a distinguished road
Hi, I have a problem with my Eulerian-Multiphase flow, the secondary phase cannot flow inside the primary phase. The primary phase is water and the secondary phase is air. I want to inject air from the bottom of the domain and it doesn't work. What should I do? Thank You
gnakrammm is offline   Reply With Quote
ansys, ansys fluent, eulerian multiphase, fluent, multiphase flow
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 13:16
Two phase flow simulation in axial flow compressor bassamelsayed CFX 3 January 6, 2023 10:53
Two phase flow problem. andyraq Fluent Multiphase 4 August 21, 2016 22:57
Mass flow rate of phase in post mat_cfd CFX 0 September 3, 2013 08:55
Divergence after change in mass flow rate in two phase flow meetsunilkale FLUENT 1 March 25, 2013 04:03
