May 10, 2024, 02:46 |
Dynamic mesh smoothing & remeshing
Been
I'm just starting to study Dynamic Mesh. I want to implement a dynamic mesh where the pink faces rotate in the direction of the red arrow and the light blue faces disappear. I've tried using profile to get the pink side to move in the direction of the red arrow, but the nodes on the light blue side are remeshing and don't merge or disappear, the cells just shrink in size, and the shape is broken. I'm wondering what options I should give to the light blue side in this situation. * I am currently using smoothing and remeshing, and have tried spring and diffusion among the smoothing schemes. * Do I need to compile the UDF separately for the light blue side? If I should use UDF, which macro should I use? I've been struggling with this for a month now. Please help ,, |
dynamic mesh, fluent, remeshing, smoothing |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 05:27 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 15:41 |
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh | Emanuele88 | FLUENT | 0 | February 9, 2016 12:39 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Update of the variables after dynamic mesh motion. | gtg258f | OpenFOAM Programming & Development | 9 | January 18, 2014 11:08 |
