UDF for battery heat generation
Old   May 9, 2024, 23:03
Smile UDF for battery heat generation
Ashutosh Sharma
ashutosh46 is on a distinguished road
I want to validate the battery heat generation model for a 18650 cylindrical LIB. Main problem is, how I can use the Bernardi eqn. For heat generation simulation. From one article, I found the correlations for resistance and entropy generation coefficient. Can you suggest me how to write UDF for it and how to implement it. An image of the necessary equations is attached.
Thank you.
ashutosh46 is offline   Reply With Quote
battery modelling, udf
Volumetric Heat Loss UDF - Surface Area and Surface Heat Flux brandonh63 FLUENT 1 November 3, 2022 06:23
Non-uniform heat flux UDF boundary condition around a cylinder climshwuling FLUENT 0 May 24, 2022 11:20
Define_profile UDF for Transient Heat flux boundary condition Amoljoshi Fluent UDF and Scheme Programming 2 June 20, 2018 22:55
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
heat generation inside fluid omernuke FLUENT 3 May 5, 2010 12:27
