Gas Mixing for Compression in Cylinder - FLUENT
Old   May 8, 2024, 16:45
Default Gas Mixing for Compression in Cylinder - FLUENT
Jackson
cucumber is on a distinguished road
I'm currently trying to investigate the compression of various gas mixtures in a piston/cylinder arrangement. I have my base simulation setup compressing air. I have also successfully completed the simulation with the predefined Methyl-Alcohol-Air mixture with it set to being an ideal gas, Inviscid and Species Transport (no reaction) parameters.
But I want to use a range of my own gas mixtures. I know how to setup a custom mixture but how do a vary the percentages of two gases in the cylinder, say 20% Hydrogen, 80% CO? I'm not using any inlets so I cannot vary it this way, but can I do it through the initial values in the Solution Initialization or is there a way I can define the gas composition in my custom mixture before hand?
Many Thanks
cucumber is offline   Reply With Quote
compression piston engine, fluent
Need help with FLUENT Mixing Plane Tutorial pchoopanya FLUENT 0 November 24, 2019 02:13
Thermal Gas Expansion of Gas in Cylinder rahulksoni OpenFOAM 4 August 16, 2017 08:59
Senior Design natural gas and air mixing problem wagoat01 FloEFD, FloWorks & FloTHERM 4 February 11, 2016 01:51
Using real gas models in Fluent neville FLUENT 1 June 5, 2012 06:54
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
