1 DOF torsional spring using dynamic mesh in combination with sliding and overset
Old   May 8, 2024, 13:46
Default 1 DOF torsional spring using dynamic mesh in combination with sliding and overset
CFD
satyamshk2 is on a distinguished road
Hi, I have a blade divided into two parts using Overset mesh. The first half of the blade is rotating about 0 0 and the second half relative to first half so 0 0. Now i want to rotate the second half about its own axis using 1 DOF spring connection with certain K. Everything works well. When I am activating the 6DOF solver and putting certain values in the , it asks for center of rotation in case of rotational spring 1DOF. In my case, it would be the blade's second half pitching point. But, there is no way to put the daming for the spring, how can i use a damper in this case?
Additional info: Blade second half is an overset zone and the first half main zone. So i want this whole overset zone to rotate as per the forces acing on the wall and respect the spring connection.
satyamshk2 is offline   Reply With Quote
1dof, dynamic mesh, sdof udf, spring-mass system
Sliding Mesh: How important is the rotating region size? drdr Main CFD Forum 0 September 13, 2022 13:53
Sliding Mesh and Dynamic Mesh AhmadHij Main CFD Forum 0 September 12, 2022 11:35
Rotating Mesh - Mesh Overlap/Discontinuity At Boundary Interface sai95kamal FLUENT 1 June 15, 2020 09:58
Qrthogonal Quality of rotating sliding mesh keeps decreasing olux FLUENT 0 September 18, 2014 05:05
initial velocity/force in six dof solver (dynamic mesh)...plz help...urgent.... sg24589 FLUENT 0 December 10, 2012 05:16
