May 8, 2024, 07:57 |
Check-valve and gap model error
Johannes
Hey there,
i am currently modeling a pressure intensifier for methyl alcohol. It consists of a check valve at the inlet (upper part), one at the outlet (lower part) and a cylinder (in between). I am getting a floating point error, when both valves are closing, creating three fluid areas, so when the cylinder is turning and going back. I wonder how to solve this error, it might be the pressure-pressure BC or the split fluid volume. I am quite new to the topic so ther might be a simple solution to this. I am using a 2d pressure based solver. Both inlet and outlet are pressure-BC, using the standart sst-k-omega-turbolence model, the cylinder is moving at 1Hz via a UDF rigid motion, valves are modeled via 1dof-solver, just as in the "check-valve" videos online. gap model for flow-blocking at the top/ sides of the valves. Layering for the moving cylinder, remeshing and smoothing for the fluid in valve-region. Thank you very much for reading. I tried my best finding a solution myself, but i have limited knowledge and could not find an answer. All i found were tutorials using air, so i think that might be the issue. |
check valve, dynamic mesh |
Sudden Movement of Spring Loaded Disc Valve at the Beginning of Simulation | SimulatorMaster | STAR-CCM+ | 4 | January 4, 2020 07:25 |
how to handle a small gap between stem and valve house | peterdog | ANSYS | 1 | November 22, 2016 06:13 |
gap between valve stem valve | kantharao | Siemens | 0 | September 2, 2008 07:19 |
Valve Forces in CFdesign | Mike Clapp | Main CFD Forum | 3 | March 8, 2001 14:09 |
cfd model of a leaking valve?? | stephen rosen | Main CFD Forum | 2 | May 10, 1999 11:44 |
