How to simulate an object moving by fluid flow inside a pipe system?
Old   May 8, 2024, 00:04
Lightbulb How to simulate an object moving by fluid flow inside a pipe system?
AsaheloMarinelo is on a distinguished road
I'm currently trying to simulate different kinds of objects (Washer, Plastic Cap, Nut, Bolt, etc) being pushed across a pipe system from Inlet to Outlet. So far I've been able to create simulations where I place the object (stationary) and observe the velocity and pressure contours.
How to generate dynamic simulation where the object moves alongside the fluid flow and reaches the outlet?. I want to also evaluate the mass flow rate differential that this object may be causing to the system. (Approximate how much restriction/obstruction is the object generating).
I've been advised to use deforming mesh (6DOF & collision detection), overset (also using 6DOF & collision detection) but I don't really know how to and have not found any tutorials online for beginners.
Thank you!
AsaheloMarinelo is offline   Reply With Quote
dynamic, fluent, massflowrate, rigidbodymotion
fluid doesn't flow inside a vertical rectangular pipe Humam121 OpenFOAM Running, Solving & CFD 0 January 9, 2021 04:15
Rod moving inside a cylinder with fluid of certain viscosity Big Kahuna Main CFD Forum 3 April 12, 2016 17:48
Unable to input fluid to flow in a hollow pipe Mrsimple CFD Freelancers 3 March 22, 2016 06:18
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
fluid flow around a half burn pipe Destry FLUENT 13 July 16, 2010 22:42
