Negative lift on golf ball simulation
Old   May 7, 2024, 06:34
Question Negative lift on golf ball simulation
jimbeet
jimbeet is on a distinguished road
I am attempting to simulate a spinning golf ball traveling through air at a certain speed. I tried employing the Moving Reference Frame (MRF) method, which involves two domains: an outer domain and an inner domain (the rotating domain). However, after calculation, the lift for the golf ball was determined to be negative, opposite to what was expected. I am unsure where I went wrong. Please provide guidance on resolving this issue. The flow speed is 18.46 m/s, and the golf ball is spinning at 1000 rpm. The mesh and solution setup are depicted in the picture below
jimbeet is offline   Reply With Quote
ansys fluent, cfd, golf ball
Golf ball simulation Ludwig Prandtl Main CFD Forum 1 July 10, 2019 05:43
NACA Airfoil simulation giving different lift coefficients in 2D vs 3D mrlam FLUENT 8 May 16, 2019 19:17
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
CFD in sports David Howell Main CFD Forum 21 July 12, 1999 07:31
