F_AREA in UDF leads to segmentation fault
Old   May 2, 2024, 18:43
Default F_AREA in UDF leads to segmentation fault
Maria Antonieta
antosan is on a distinguished road
I need to calculate the area of all faces within a given domain. What I did is the following:
  1. To learn how to write the UDF, I looked into the ANSYS UDF MANUAL and I found a code that outputs a similar information for each face, i.e. the location of the centroids of the cells (page 225). This code is shown below (CODE 1). This code works and I am able to output a file with the centroid information.
  2. When I adapt this code for outputting the area of each face within a domain, I receive a Segmentation fault. The adapted code is CODE 2, below. I debugged the code and the issue occurs when the code runs into the F_AREA(A,f,t) macro.
  3. FYI- I am not running in parallel.
My approach is to compile the UDF and load it to DEFINE_ON_DEMAND.
I would appreciate if you give me any advice on this.
THANK YOU!
CODE 1: IN ANSYS UDF MANUAL FOR CENTROID CALCULATION (WORKS)
#include "udf.h"
FILE *fout;
void Print_Thread_Face_Centroids(Domain *domain, int id)
real FC[3];
face_t f;
Thread *t = Lookup_Thread(domain, id);
fprintf(fout,"thread id %d\n", id);
begin_f_loop(f,t)
F_CENTROID(FC,f,t);
fprintf(fout, "f%d %g %g %g\n", f, FC[0], FC[1], FC[2]);
end_f_loop(f,t)
fprintf(fout, "\n");
DEFINE_ON_DEMAND(get_coords)
Domain *domain;
domain = Get_Domain(1);
fout = fopen("faces.out", "w");
Print_Thread_Face_Centroids(domain, 23);
fclose(fout);
CODE 2: ADAPTATION FOR AREA CALCULATION (DOES NOT WORK)
#include "udf.h"
FILE *fout;
void Print_Thread_Face_Area(Domain *domain, int id)
real NV_VEC(A);
face_t f;
begin_f_loop(f,t)
fprintf(fout,"inside loop\n");
F_AREA(A,f,t);
/*fprintf(fout, "f%d %g \n", f, NV_MAG(A)); */
end_f_loop(f,t)
DEFINE_ON_DEMAND(get_facearea)
Domain *domain;
fout = fopen("faces_areas.out", "w");
Print_Thread_Face_Area(domain, 23);
fclose(fout);
antosan is offline   Reply With Quote
ansys, fluent, f_area, segmentation fault, udf
UDM segmentation fault. Tushar_Telmasre Fluent UDF and Scheme Programming 1 March 24, 2017 06:45
Segmentation fault in SU2 V5.0 ygd SU2 2 March 1, 2017 05:38
fatal signal segmentation fault in a UDF hares FLUENT 6 January 21, 2017 04:26
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 15:38
