Connect two fluid zones in hydrogen dispersion modeling
Old   April 30, 2024, 03:16
Default Connect two fluid zones in hydrogen dispersion modeling
Thang
halihosa is on a distinguished road
Hello
I'm new to Ansys fluent and I have been struggling for a while with this.
My task is to assess the safety of hydrogen diffusion in cars during accidental leakage as described in Fig. 1 below. The hydrogen leaks from the orifice to the car compartment and exhausts through the sunroof. I tried to use Boolean in the design modeler to subtract the hydro tank from a car. I also set the car geometry to wall. I do nothing with the diffusion domain and car. But it seems to be wrong cause the result shows that the streamline of air inlet goes through the car geometry and the hydrogen stream does not go out of the car Fig 2. I read some posts and interface/ mesh contact may be the best solution but I don't know to to set up them. Can anyone tell me what should I do to correct this task?
Thanks in advance for the help ^^
Fig 1: https://drive.google.com/file/d/12ms...ew?usp=sharing
Fig 2: https://drive.google.com/file/d/1zrc...ew?usp=sharing
halihosa is offline   Reply With Quote
contact, hydrogen diffusion, interface
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Modeling carbon nanotube as particle in fluid terktor FLUENT 0 January 1, 2016 18:54
Modeling Solid and Fluid at the same using Interface BC..Help needed Prince Jassal Main CFD Forum 1 June 12, 2013 06:07
Help on Fluid dynamic modeling kdk Main CFD Forum 0 May 27, 2002 07:01
Help With Modeling A Projectile Fluid In Flight. Dzeff G. Main CFD Forum 0 December 10, 1998 22:24
