Divergence in AMG solver:pressure coupled but no iterations performed |
April 25, 2024, 15:01 |
Yash
Hello, I am having issues with my CFD attempt. I am using Ansys Fluent Student edition 2024 R1. I have tried multiple youtube tutorials as well as asking some of my professors but am unable to find a solution to my problem. It gives me the error saying "Divergence detected in AMG solverressure coupled.". I have tried improving my mesh as well as lowering the Under-Relaxation factors to no avail. I am attaching my mesh statistics and the geometry. I am also adding the console logs as a part of this post
It's a 2D axisymmetric simulation with inlet velocity of 50 m/s (although I did attempt 10 m/s too). My mesh metrics are as follows Max Aspect Ratio: 2.05 Min Element Quality: 0.43896 Max Skewness: 0.55119 Min orthogonal quality: 0.7162 I am under time constraints so any expedited help would be much appreciated. Thank you in advance. |
April 26, 2024, 10:32 |
I figured it out
Yash
All I had to do was rotate my model 90 degrees so that the axis aligned with the x-axis in ansys. Found it out by troubleshooting and experimenting with a different geometry. Hope this helps for anyone else who has this problem in the future.
axisymmetric 2d fluent, error #f, help for a newbie, help me |
Error SIGSEGV using VOF and UDF | JERC_UTFSM | Fluent UDF and Scheme Programming | 14 | November 7, 2021 23:17 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
