Rico Lüthi
Rep Power: 0 ![]() |
Hello together
I am simulating a hot water tank which is located in a lake. A picture of the setup is attached. The water in the tank is at rest (no flow) and under normal pressure. The lake has a current of 0.1 - 0.5 m/s. The important thing for me is the heat dissipation of the storage tank (heat transfer through the insulation) and the temperature distribution in the storage tank. I only have a laptop at my disposal, which does not have a lot of computing power and only has limited time. Which flow model should I use so that my computer is not completely overloaded? My mesh has approx. 700,000 elements, I should carry out a transient simulation. Can I use the k-epsilon model or is there a more efficient method? And with regard to the Courant number: What is the maximum number that can be used? I hope one of you can help me. Please let me know if you have any questions. Kind Regards Rico Lüthi ![]() |
courant number, heattransfer, transient 3d, turbulence models |
How to set the flow courant number in the Coupled model of Fluent? The default is 200 | hitzhwan | FLUENT | 4 | October 10, 2023 22:03 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
Problems with Courant number (LaunderGibsonTurbulence Model) | sven | OpenFOAM | 3 | August 10, 2009 03:12 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
