How to simulate the drying process of porous media in Fluent |
April 8, 2024, 01:48 |
birdsong
Hello teachers and seniors!
I need to simulate the drying process of a porous medium and I am having some problems. The model is very simple, a vertical channel from top to bottom, with a certain thickness of porous media located in the middle of the channel, hot air blowing from the top to the bottom, which has a certain temperature, humidity, speed, while the porous media also has a certain moisture content. I need to simulate the drying of a porous medium under hot air with different temperatures and velocities, and investigate the changes in temperature and moisture content of the porous medium during the drying process. Should I add an energy source term and a component (h2o) source term at the porous medium or use UDF or UDS, and if so, how should I add the source terms? Do you have any suggestions? What model should I use? I don't know if what I said up there is correct. and I would appreciate your guidance! If you have modeling information, you can share it in my email, thanks! |
drying, fluent, help me, porous cell zone |
What is the Formula used behind FLUENT on Moisture Diffusion on Porous Media? | elwinxavier | FLUENT | 0 | October 19, 2020 01:47 |
Porous media in FLUENT | Dounia | FLUENT | 2 | July 3, 2019 05:12 |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 15:11 |
Modelling flow thru wet porous media in fluent???? | Abhya | FLUENT | 0 | September 2, 2012 03:59 |
Porous media Definition in FLUENT | Rashmi | FLUENT | 0 | May 13, 2006 01:55 |
