ParaView (Fluent Data) > How to show contour? |
March 27, 2024, 03:21 |
Andreas
Rep Power: 4 |
I exported my Fluent Data to encas and I read my Data with the "EnSight Reader". Under "Point Arrays" I see my exported Data and everything is selected: Point Arrays: - pressure - total_pressure - velocity - velocity_magnitude So I press "Apply" to read the Data. It starts reading my data but I get the following errors: Code:
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\IO\EnSight\vtkEnSightGoldBinaryReader.cxx, line 348 vtkEnSightGoldBinaryReader (0000017E3BE48CD0): Invalid part id; check that ByteOrder is set correctly. ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\IO\EnSight\vtkEnSightReader.cxx, line 297 vtkEnSightGoldBinaryReader (0000017E3BE48CD0): error reading geometry file ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 753 vtkCompositeDataPipeline (0000017E2F8878F0): Algorithm vtkEnSightGoldBinaryReader(0000017E3BE48CD0) returned failure for request: vtkInformation (0000017E3C115680) Debug: Off Modified Time: 519500 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 ALGORITHM_AFTER_FORWARD: 1 FROM_OUTPUT_PORT: 0 Thanks |
fluent, paraview |
[OpenFOAM] Error importing transient OpenFoam decomposed data with Paraview on Windows 10 | yek_irani | ParaView | 0 | July 6, 2019 10:39 |
Any way to extract data from contour plots using paraView? | Angela Wang | OpenFOAM | 10 | December 3, 2017 21:37 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Fluent crash on writing data file after thousand iterations | Chuck87 | FLUENT | 0 | September 2, 2015 17:17 |
[OpenFOAM] extracting data from paraview | tharem | ParaView | 1 | January 18, 2011 00:45 |
