March 13, 2024, 18:12 |
Varying results in fluent when varying mesh
Mostafa Kamal
Rep Power: 2 |
Hi everyone
My case is turblent and transient flow for simulations gas turbine in wind tunnel Free stream velocity 33.5m/s and Re No. 5.6*10^5 When generate 1st case mesh general element size is 8.4mm and blade wall size is 3 mm with sweep method ;when run this case total pressure losses at outlet is 0.3 Than 2nd case when canceling sweep method in mesh and run case in fluent the total pressure losses at outlet be 0.36 Which result true? Is that must make inflation or not ? Last edited by Moka; March 14, 2024 at 06:07. |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 16:16 |
[ICEM] Exporting good ICEM mesh to Fluent results in poor quality mesh | balrog_f | ANSYS Meshing & Geometry | 3 | October 17, 2021 03:43 |
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces | Hamid.de | Pointwise & Gridgen | 4 | November 9, 2016 12:20 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 22:41 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
