CFD Model
Old   March 3, 2024, 05:07
Default CFD Model
Ashar Ali
asharali067 is on a distinguished road
in my reference paper writed
In the meshed models, ten divisions are made across the film thickness excluding the groove portion and further applied multizone mesh method and body sizing of 0.1 mm.
what is the definition of ten divisions? thank you
asharali067 is offline   Reply With Quote
Old   March 3, 2024, 18:58
Default Mass flow Pulsation
Masoud Hatami Garousi
Masoud68 is on a distinguished road
Hi everone
I am simulating a pulsative flow in the suppressor (attached photos )
Inlet B.C is pulsative mass flow rate, for outlet B.C I used ambient pressure for outlet B.C but the results weren't reasonable. The inner diameter is 20 mm, and the fluid is hydraulic oil with an 850 density and 0.039 viscosity. Also, the chamber diameter is 50 mm.
I am wondering if I can use constant pressure in the outlet B.C while using a pulsative flow inlet?
Masoud68 is offline   Reply With Quote
grooves, journal bearing
Fixed Temperature Constraint problems for coal combustion yglovella OpenFOAM 0 February 16, 2023 02:00
Question about inviscid model in CFD software Adorkable Main CFD Forum 5 November 27, 2022 07:46
Verification and validation of a CFD model gartz89 FLUENT 0 December 5, 2021 04:14
CFD Salary CFD Main CFD Forum 17 January 3, 2017 18:09
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
