March 1, 2024, 05:25 |
Circumferential averaging over time
Eglantin Gjoni
Rep Power: 3 |
Hi all,
I am currently running a 3D-CFD simulation of an axisymmetric body. I modeled only a 18deg sector and I'm applying periodic boundary conditions. The simulation started to oscillate (although it's steady state), therefore i switched to transient and saw that oscillation persisted. I assumed therefore it's physical, and proceeded to compute FFT of some of the monitor points I had place getting the frequency of oscillation based on the time-step I was using. Now here's the catch. Since I am interested in extracting circumferential-averaged profiles at specific locations of my geometry, I can proceed with with the circum-avg-radial command in the TUI. However, my solution is not steady, therefore a time-average is needed. The first question is: how do I take the circumferential average over few periods of the oscillation? I tried setting up a radial-bands and monitoring over time (via surface report) the quantities I need for each band, but then I loose information about the exact location of the band as I only get the numbered-band and the quantity. The second question is: how do I do the same thing but for multiple locations? When setting up a radial-band via circum-avg-radial in the TUI, you can set only one radial-band and if you try to create another one in a different location then the previous radial band is deleted and the new one is created. I don't want this. I want to monitor circumferential averages, again averaged over time, at different locations. Any help would be very much appreciated. Thank you! PS: Please note that I have no experience in setting up user defined functions (UDF) to by-pass the problem. |
March 12, 2024, 07:44 |
Fwd
Eglantin Gjoni
Rep Power: 3 |
Hej guys, any clue?
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 14:47 |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 11:54 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
