Divergence detected during single particle deposition analysis |
Diego Garcia
Rep Power: 7 ![]() |
Hello everyone,
I have had a particle sedimentation problem for some time that I have not been able to solve. I want to run a transient simulation of freely falling single particle in 2D as well as in 3D, in a Viscous Stagnant Fluid. To do this, I use overset mesh method and SixDOF solver to solve compute external forces and moments resulting from the interaction of the body with the fluid. For this, I also have used a UDF in which I defined the properties of the SixDOF Solver ( mass and moments of inertia) and which was also adapted to track the components of the velocity of the CG during the fall. I have already tested it and it is functional, however when I define very small mass units for the solver (1e-3 kg, 1e-4 kg...) divergence is detected in AMG solver with a floating point exception. I have tried many options and I have not been able to solve it, I have changed the mesh, with quality monitoring, trying different meshing methods, turbulence models, CFL number, different time step size, using dynamic meshes instead of the Overset mesh method , different solution methods, pressure-velocity coupling, One DOF analysis but nothing has worked. If anyone has experience on this topic, please suggest me something helpful. I can share the case files and images. I am using Ansys Fluent 19.3, 22R1 or 23R2. Thanks and excuse me for my english! |
Diego Garcia
Does anyone have an idea to solve this problem?
divergence amg solver, fluent - udf, freely falling, overset mesh, sdof_properties |
Population Balance Modeling (PBM) - Ansys Fluent | chittipo | FLUENT | 164 | November 18, 2023 11:54 |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 4 | September 25, 2023 07:10 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Divergence detected in AMG solver: k, epsilon, pressure coupled | Tanjina | FLUENT | 5 | January 13, 2014 10:46 |
Floating point error and divergence detected | aannjj | FLUENT | 0 | July 2, 2013 03:44 |
