Modelling of room with exhaust ventilation
Old   February 14, 2024, 08:13
Post Modelling of room with exhaust ventilation
Jean Paul Harrouz
jpharrouz is on a distinguished road
I am modelling a room with exhaust ventilation system, with an extraction fan. I know the cross-section of the air outlet (50 x 60 mm) that if exposed to a pressure jump of 80 Pa will cause a flowrate of 135 m3/h. I first simulated the problem with a pressure inlet BC (with 0 gauge pressure as it takes air from the atmospheric pressure) along with exhaust fan and a pressure jump of 80 Pa (I used a positive value). I used tried all k-e models with SIMPLE p-v coupling, PRESTO! for pressure solver and second order upwind schemes for all variables in steady state regime. During the simulation, I had reversed flow faces on both inlet and outlet with 26 % and 49 % of their respective areas. I then used first order upwind for Momentum equation and I was able to get rid of the reversed flow at the inlet only. Moreover, when I checked the mass flowrate at the inlet, it was considerably lower than the target 135 m3/h.
I finally used as BC: inlet vent and mass flow outlet with the impose 135 m3/h (or 0.45 kg/s) using the same schemes as before and the solution was very smotth with small residuals (all below 10^-4). However, when I checked the static pressure at the outlet, it was -168 Pa.
Hence my question, since I know the fan exhaust flowrate, can I direclty use it with the 'Mass flowrate outlet' BC instead of having the 'exhaust fan' BC and will this affect my end resullts?
PS: the inlet and outlet locations are very far from each others.
Thank you in advance!
jpharrouz is offline   Reply With Quote
exhaust fan, exhaust system, fluent, mass flow outlet, outlet boundary condition
1D Modelling of Mechanical Ventilation Network in OpenFOAM charles4allme OpenFOAM Running, Solving & CFD 4 May 16, 2018 11:25
Modelling room ventilation air flow todda7 Main CFD Forum 0 April 12, 2017 15:51
a room mechanical/natural ventilation case vaina74 OpenFOAM 2 October 30, 2014 04:17
examples of simulation on room ventilation? lei FLUENT 1 June 20, 2003 23:38
Modelling Flow from an Exhaust Bob CFX 0 July 26, 2002 06:38
