Modeling Heat and Mass Transfer through membrane in ANSYS FLUENT
Old   January 31, 2024, 06:05
Default Modeling Heat and Mass Transfer through membrane in ANSYS FLUENT
Ali Qasim
Ali_qasim is on a distinguished road
Hi everyone,
I am new to modeling heat and mass transfer using ANSYS FLUENT.
I am trying to model the heat and mass transfer from hot air (air+vapor mixture) to liquid solution (water+salt mixture) through a membrane using ANSYS FLUENT. The vapors from the hot air side is being transferred to fluid side through membrane and it is being absorbed in liquid solution (changing the phase). This mass transfer has been modeled with the use of UDF.
I have turned ON the "Energy" and "Species Transport" models.
Using aforementioned settings , ANSYS FLUENT does not consider the effect of heat due to phase change of (vapors into liquid solution) in analysis.
Do I need to model by treating as multi-phase flow? or there any other way to consider the effect of this phase change heat?
Can I modify the energy equation by developing a UDF?
Regards,
Ali_qasim is offline   Reply With Quote
ansys fluent, heat and mass transfer, membrane, phase change, udf
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 20:24
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 22:42
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
