Odd convergence behaviour in VOF independant of mesh, CFL, gradient schme |
January 30, 2024, 05:32 |
Rep Power: 3 |
Dear CFD experts,
I observe odd convergence behaviour in transient VOF: At some point, when the flow situation gets more complex, residuals begin to stall for some timesteps (oscillating around 1e-4 to 1e-6). Looking at the cell-specific residuals it is because of momentum and/or energy residuals in some cells (0.01% of mesh) where residuals rise so high, that it "destroys" the global residual. Often it is just 2 cells at a wall or an interface that are affected. At least the solver does not diverge and keeps running (although at very small timestep, due to the error the flux-controlled adaptive timestep decreases to CFL~0.2). After some time residuals behave normal again, i.e. they drop below the target value of 1e-7 within 30 iterations. The problem is very persistent, I tried the following: * change timestep to CFL=2, 1, 0.5 (no effect) * decrease mesh size 1/2 and 1/4 (finer mesh make this worse, slower progress due to lower timesteps) * adding 10 boundary layers at walls for y+<100 (make things worse) * 1stOrder, 2ndOrder with HOTR instead of QUICK (no effect) * differentiable spatial limiter (no effect comp to default) * acivate energy noise filter (no effect) * GMRES instread of BCGSTAB (no effect) * AMG off (coarsening levels =0, had a positive effect, otherwise divergence or velo/temperature limiting) Basic case infos: 2ddp, pbcs, kwsst, phase1=air ideal-gas, phase2=incompressible fluid, homogenous VOF explicit with GeoReconstruct, transient first order, pressure level 1e7Pa, Velocity Range 10...400m/s, Temperature 800K Mesh stats (for non-BL mesh): 12k cells, Mostly Quad Elements, Min Orthogonal Quality=0.3, Max Aspect Ratio=6.7, no negative volume or areas I added some images (vof and T residual) close to the end of the filling simulation at 95% fillfraction. Not the best example, but it happens for very good cells (perfect squares), too. Any ideas what could be the issue? Last edited by DrZoidberg; January 30, 2024 at 06:01. Reason: added mesh stats |
amg solver, compressible air, convergence, incompressible fluid, multhiphase |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 14:37 |
