Rep Power: 2 ![]() |
When simulating the total energy I get negative values?
Why is the total energy negative? Is it because total energy is usually positive from fluids to surroundings but did I plot here the energy transfer from surroundings to fluid? I wanted to plot the contour without selecting a surface but I couldn't do this so I had to select the three pipes and the back and side walls. Did I then plot the energy of the walls and pipes instead of air or what do these results mean? |
energy, simulation, total |
Turbulence dissipation vs Viscous dissipation | granzer | Main CFD Forum | 18 | January 10, 2022 00:27 |
Negative temperature/internal energy in modified rhoCentralFoam | Dr.Wan_Li | OpenFOAM | 0 | October 1, 2020 09:43 |
Error in run Batch file | saba1366 | CFX | 4 | February 10, 2013 01:15 |
LES and total turbulent kinetic energy | Boerge | FLUENT | 1 | September 8, 2012 11:41 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
