Cylinder Vortex Shedding URANS
Old   January 25, 2024, 16:29
Default Cylinder Vortex Shedding URANS
toni_rt is on a distinguished road
I'm using the SST k-omega turbulence model to simulate some cylinders in crossflow in a rectangular channel. Disregarding the wall effects and the cylinder-to-cylinder interaction, I should see a shedding frequency of approximately 3kHz at the current Reynolds number (1e5). I'm just using a pressure inlet and outlet. First, I run the steady solver until there is convergence. Then, I run the 1st order unsteady solver with an adequate timestep (10 times smaller than the theoretical shedding period). The problem is that I cannot trigger the shedding, and even with a different solution initialization, the oscillations seem to dampen out. The unsteady solution in time looks just like the steady one. Based on the previous posts on this forum I understand it will be difficult to replicate the expected frequency, but at least I should be able to see it. Do you have any recommendations on how I can tweak the model to sustain the vortex street? I'm attaching some screenshots and the fluent settings summary. Thank you!
Last edited by toni_rt; January 25, 2024 at 17:08. Reason: uploaded supporting screenshots
toni_rt is offline   Reply With Quote
fluent, k-omega sst, urans, vortex shredding
Flow Past a Cylinder, the Onset of Vortex Shedding Nauseouslyquick Main CFD Forum 3 October 23, 2016 17:46
no VOrtex Shedding flow past a 2D cylinder Sufyan Main CFD Forum 7 November 16, 2012 02:13
Vortex Shedding & Cd on Cylinder Franciswu21 FLUENT 0 March 20, 2009 13:29
Flow around a cylinder Vortex Shedding ForceCoeffs harly OpenFOAM Running, Solving & CFD 1 November 3, 2008 01:50
Vortex shedding for square cylinder zonexo Main CFD Forum 8 March 30, 2006 16:11
