Pressure-outlet temperature problem
Old   January 19, 2024, 07:21
Default Pressure-outlet temperature problem
Sebastien
sfawn is on a distinguished road
I've got a 2d multi-phase flow with 3 phases: argon, liquid "frozen" copper and liquid "frozen" chromium (I am doing solidfication and melting simulation and at the initialization the temperature is below the melting point of both metals).
The initialization is shown on the attached image, but when I run the simulation for 4 timesteps (my energy source term turns on at the 5th time step), I don't understand why I get some copper on the gas boundary, which also have a temperature of 300K (which was my initial temperature before, but I changed the material reference temperatures of copepr and argon, the operating condition temperature and the initial value at initialization to 1300K
I also get these messages at each iteration : Reversed flow on XX faces of pressure-outlet X, I don't know if this is linked with my issue
Can anyone help me understand what is happening please ?
sfawn is offline   Reply With Quote
Old   January 19, 2024, 08:19
Sebastien
Well in the end I already solved this
In the boundary conditions, I only changed the values for the mixture phase, but not for the secondary phases.
I only put a backflow volume fraction to 1 for the gas phase and it fixed my issue !
Old   January 23, 2024, 12:37
CamsDR is on a distinguished road
I also have a problem where I get this warning: Reversed flow on XX faces of pressure-outlet.
Do you know what it means?
CamsDR is offline   Reply With Quote
Old   January 23, 2024, 12:41
Sebastien
Originally Posted by CamsDR View Post
I think it means that you get a flow entering your domain from the outlet, which generates this message
From what I've quickly read online, it can slow down your convergence but is not that bad for your simulation
Maybe a bigger domain could help with this ? I haven't try sorting this as my simulation now work despite these warnings
Old   January 31, 2024, 00:49
gbert27455 is on a distinguished road
In the boundary conditions, I only changed the values for the mixture phase, but not for the secondary phases. Donkey Kong
OHH! Glad you found a method.
gbert27455 is offline   Reply With Quote
boundaries condition, multiphase, pressure outlet
Pressure Drop Measuring Problem engineerm Main CFD Forum 4 June 16, 2023 05:31
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
