January 19, 2024, 02:32 |
Curved Domain
I am currently working on a CFD cornering set-up for Ansys Fluent but with no success.
For the boundary conditions, I have set the floor and walls to full-slip condition and the wheels to not rotate. On the other hand, the air has been set to rotate around the centre of the wind tunnel using frame motion; the inlet velocity is set to zero and relative to the adjacent cell zone value, as this one already has the velocity value set on the MRF; and a gauge pressure set to zero for the outlet. I have worked with other conditions but until the moment these are the ones giving the most coherent results. Attached below you will find three pictures regarding the domain and boundary conditions as well as my latest result using a simple geometry. |
Domain size influence in unbounded domains model | Reoyo | Main CFD Forum | 10 | May 4, 2018 09:30 |
Conformal mapping of a curved channel to a rectangular domain | alinik | Mesh Generation & Pre-Processing | 0 | August 6, 2017 14:25 |
Periodic Pressure drop | cfd_begin | CFX | 10 | May 25, 2017 08:09 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 11:38 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 04:14 |
