wall temp- hydrogen fueling
Old   January 15, 2024, 10:03
Default wall temp- hydrogen fueling
Simon Gronau
Simon1303 is on a distinguished road
<p>Hello friends,</p>
<p> i want to simulate filling a tank(0.3 Litres) in 3 D with hydrogen with a defined mass flow (real gas hydrogen). I want to see how the temperature and pressure increase. My problem is the wall temperature do not change. In mesh i did a manual contact region and so my wall should be connectet to my fluid (hydrogen). I did that simulation in 2D and my wall temperature did change.</p>
<p>Maybe the problem is because i patched my wall temperature to 293K? But why did the wall temp. change then in 2D (also manual contact in mesh)? i also didnt do shared topology or built from the 2 cylinders(wall body and fluid body) 1 part.</p>
<p>Do u also can tell me if my simulation does make sense? Only after 2 seconds my temperature went from 256K to 400K and from 1 bar to 38 bar (temperature do not increase any more really). I could explain to myseld because of the &quot;high&quot; mass flow and the &quot;low&quot; volume from the tank. Is it normal that the temp goes straight to the back of the tank?</p>
<p>My conditions:</p>
<p>m_H2_flow=0.8 g/s, T_H2=256K k-eps, enery eq. on</p>
<p>op. cond 1bar (floating cond. on), timestep size 0.05, iterations 35, free steam 293K and 10 W/m&sup2;K</p>
<p>Patch: wall temp_293K</p>
<p></p>
<p> Thanks in advance</p>
Simon1303 is offline   Reply With Quote
wall temperature
Illegal cell label -1, fluent3DMeshToFoam BenGher OpenFOAM 7 October 10, 2023 01:02
[snappyHexMesh] How to draw a 3D-Drawing for Meshing Kahnbein.Kai OpenFOAM Meshing & Mesh Conversion 4 June 15, 2021 13:16
What's the problem with turbulence models near the wall region? Jaydi_21 Main CFD Forum 6 July 7, 2017 03:39
[mesh manipulation] mergeMeshes problem Attesz OpenFOAM Meshing & Mesh Conversion 3 July 29, 2015 05:15
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
