How to manage a metallic foam on ANSYS FLUENT
Old   January 12, 2024, 14:26
Unhappy How to manage a metallic foam on ANSYS FLUENT
mario renzoni
m.marriooo is on a distinguished road
Hi at all!
I have an important question for a project work that i'm following.
My geometry is a simple Fin heat exchanger in which two serpentine tubes, through which two different generic fluids flow, are surrounded by a metallic foam with assigned thermal conductivity, specific heat, and density properties.
I am wondering how to correctly model this solid zone. The option specified is "porous media," but this can only be activated for fluid cell zones. Therefore, is it correct to select them as simple "porous jump"?
It is important to note that there is no fluid flowing inside the foam; it only surrounds the two copper tubes.
Additionally, do you think it is more accurate to activate 'radiation' and consider the possibility that the two tubes exchange radiation due to the porosity of the medium?
Thanks a lot!!
m.marriooo is offline   Reply With Quote
metallic foam, porous cell zone, radiation exchange
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Model Porous Foam Using Ansys Fluent fareastzs21 FLUENT 0 February 4, 2015 21:49
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
