January 11, 2024, 14:33 |
Curvature sizing not meshing properly
Rep Power: 5 |
I'm trying to mesh a bent tube that is a circular cross section. I have a similar case that worked perfectly, but am testing something and wanted a coarser mesh to get the test working.
Essentially, I have a curvature sizing for this tube, with a max of 20mm, which is a shared sizing between this and other parts. Because the tube is small, I expect the curvature capturing to come into play, as the min size is 1mm. The tube should be meshed with ~5mm sized elements. Instead it defaults to some large size and the tube comes out completely distorted and like a ribbon in some locations: https://puu.sh/JYAJt/13e6edbdba.png I forced the sizing to a max of 5 and it meshes perfectly. The tube is also in a BOI, which I reduced the size of, and this seemed to also refine the mesh. But this makes no sense, the BOI is more than double the surface sizing, it should not take priority. Again I copied my size settings from a working case, and it won't work. Any ideas? EDIT: The issue is not present in 2023 R1 (I'm using R2). Anyone else encountered this? Last edited by cons013; January 12, 2024 at 01:36. |
January 12, 2024, 19:35 |
Lorenzo Galieti
Rep Power: 12 |
The BOI should have its own surface settings if i recall well.
1/4 Quadrants not meshing properly? | student550 | FLUENT | 0 | October 27, 2018 19:58 |
Meshing of a formula student racing car | Scientifix | FLUENT | 1 | August 31, 2018 14:32 |
[ANSYS Meshing] difference between hard/soft behavior in sizing in ANSYS meshing? | swamy339 | ANSYS Meshing & Geometry | 1 | August 19, 2013 14:38 |
[ICEM] ICEM sizing function >>> Gambit and Ansys meshing | Far | ANSYS Meshing & Geometry | 6 | March 5, 2013 02:16 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 12:09 |
