Two way FSI bearing
Old   January 11, 2024, 09:02
Default Two way FSI bearing
Kirill
Schwarz2012 is on a distinguished road
Hi everyone!
I'm trying to repeat the model for determining the equilibrium position of a bearing shaft, which I found on the Ansys website (Analyzing Fluid Film Bearings and Rotordynamics with ANSYS), it was made in version 16, I work in 22R2 and just can’t achieve convergence. I know that the System coupling 2.0 was added in release 19 and I think that is the reason. Are there people here who solved a similar problem in last versions of Ansys? Can anyone help with this problem?
Schwarz2012 is offline   Reply With Quote
Old   October 11, 2024, 07:38
Dinesh
Dinesh_Dhande is on a distinguished road
Have you got the problem solved?
Dinesh_Dhande is offline   Reply With Quote
[FSI] Sudden divergence of elastic pipe FSI MFWilliams OpenFOAM CC Toolkits for Fluid-Structure Interaction 1 June 16, 2022 12:35
[solids4Foam] FSI case does not converge, foam extend 4.0 MFWilliams OpenFOAM CC Toolkits for Fluid-Structure Interaction 12 May 13, 2022 09:35
Multiphase Journal Bearing CFD: Modelling Air Entrainment eaxym CFX 1 May 13, 2014 20:29
Air bearing modelling Dave Larkham CFX 1 October 19, 2008 20:10
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
