Effect of gravity in verticle pipe - balancend condition?
Old   January 11, 2024, 06:32
Default Effect of gravity in verticle pipe - balancend condition?
Moritz Kuhn
MKuhn is on a distinguished road
Dear all,
I would like to model the suction of water through a 5 m long vertical pipe, length in y-direction.
Model setup:
  • vertical tube
  • multiphase mixture model, primary phase water-liquid, secondary phase water-vapor
  • gravity on (-y-direction), variable density method: mixture averaged
  • operating pressure 0 Pa (because I define in the evaporation/condensation model the saturation temperature depending on the static pressure)
  • pressure inlet 100,0000 Pa gauge pressure, water liquid
  • setting the pressure outlet in this way that the liquid column will reach the middle of the tube 75,000 Pa
  • initialize and patch the entire domain with water vapour
  • the solution converges, fluent calculate a massflow according a pressure drop of 25,000 Pa, as if the gravity of the water does not exist.
What is going wrong here?
Moritz
MKuhn is offline   Reply With Quote
outlet boudary condition for a flow in the pipe Atit CFX 2 November 9, 2004 18:43
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 10:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Effects of gravity in pipe - pressure distribution Anthony Wachs FLUENT 2 July 25, 2001 08:07
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
