How can I transform pressure fluctuations into frequency domain signal in Fluent? |
Darwin
Rep Power: 3 ![]() |
Hello everyone. I'm working with a centrifugal fan modeled in the transient regime to study the Sound Pressure Level (SPL). I've employed a set of probes to monitor the pressure in the fan discharge and capture the fluctuations necessary for noise analysis and spectral analysis.
Now, my question is: How can I convert time-accurate pressure data into a frequency domain signal to represent the fan's noise? While Fluent offers the Time Fourier transform option, it seems to be designed specifically for acoustic receivers. In my case, all monitor pressures were configured as points within the domain at specific coordinates at the fan discharge (see attached figure). Thanks in advance...! |
Rep Power: 7 ![]() |
![]() you can import time vs pressure data into FFT to post-process it in frequency domain. To consider for multiple dataset from many points, i believe you have to post-process it outside of fluent. Correct me if i'm wrong tho Last edited by lolno; January 5, 2024 at 10:00. Reason: fixed image link |
fan analysis, noise, sound pressure level |
reverse flow in centrifugal fan blades | kalm | CFX | 20 | December 2, 2023 06:25 |
PEMFC tutorial case problem | Suleyman41 | FLUENT | 2 | July 15, 2023 11:16 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Different kinds of pressure in FLUENT | Mattia | FLUENT | 0 | October 22, 2007 08:52 |
