The energy problem when solving cavitation in FLUENT |
December 30, 2023, 13:06 |
Rasl
Rep Power: 2 |
Hi all.
I am simulating the operation of a centrifugal pump. I did the calculations on the water, everything is fine. Previously, I saw a tutorial on HOW TO from ANSYS: https://www.youtube.com/embed/bgdBrOBuNgQ and my settings are also the same, inlet pressure and outlet mass flow. Next, I need to calculate cavitation, I also paid attention to the video from ANSYS: https://www.youtube.com/watch?v=9E3Q-cqhkVw My settings are the same again. My problem is that the calculation starts and the energy and continuity grow greatly, which leads to an error: I tried all the settings but nothing helps (changed methods, reduced relaxation coefficients, switched to stationary mode + pseudo transient, changed turbulence options k-e, k-omega, etc.). I used substep time steps of 0.001, it seems that this is not enough. I made a new calculation with a step of 1e-5, it was very long and left it to be decided further, the graph is already like this: Can this help? Should you take an even smaller step? The calculation will take even longer, I'm using 48 cores. Thank you. |
January 5, 2024, 11:18 |
Rep Power: 7 |
do you mind showing a cross section of your mesh? and how's your mesh quality metrics?
rhoSimpleFoam High Pressure Cell Crashes Simulation | NorthCFD | OpenFOAM Running, Solving & CFD | 0 | March 3, 2023 06:02 |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 15:26 |
Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 18:45 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 05:13 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
