Calculation of a centrifugal pump in fluent
Old   December 30, 2023, 12:44
Default Calculation of a centrifugal pump in fluent
Rasl
javat33489 is on a distinguished road
Hi all.
We have two wonderful videos on calculating a centrifugal wheel (ANSYS "HOW TO"), the first is a flow calculation, the second is a cavitation calculation. It is perfectly! Thank you.
https://www.youtube.com/watch?v=9E3Q-cqhkVw
https://www.youtube.com/watch?v=bgdB...ZsdWVudA%3D%3D
Now the question. How to set a mixture pumping for a centrifugal pump? After all, one of the main conditions for the calculation is to establish the mass flow rate at the outlet of the pump, and because of this, it is not possible to correctly set the mixture at the inlet and outlet. In addition, there is help from the tutorial, which also does not include the possibility of such a calculation:
Tell me what to do in such a situation? Thank you.
javat33489 is offline   Reply With Quote
Why am I getting negative pressure head of the Centrifugal Pump through CFD? raza48919 FLUENT 6 April 26, 2023 15:11
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 13:16
Problem with centrifugal pump calculation Michiel Main CFD Forum 2 June 17, 2012 22:32
centrifugal Pump Efficiency A.farid Main CFD Forum 0 March 31, 2012 08:39
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 09:00
