December 25, 2023, 09:16 |
Steam Through Nozzle
Zohaib Altaf
Rep Power: 7 |
Hello everyone, i am facing an issue while solving steam flow through a nozzle in Ansys fluent
Fluid: water vapor BCs: Pressure Inlet (2000 kPa, 493 K) Pressure Outlet: variable pressure like1800, 1600, 1400 kPa , etc along with total temp of 493 K) Issue: The problem is steam flow through nozzle never gets choked no matter how much pressure i reduce at outlet, the mass flow keeps on increasing. Note: i think there might be a problem in using water vapors as fluid here, it appears that this fluid is built in fluent and has constant density, which might not be suitable in this case. Need serious help, thank you in advance. Last edited by zohaibaltaf.6; December 26, 2023 at 10:26. |
nozzle analysis, steam |
Convergent nozzle and preesure of steam | pranabjyoti | CFX | 7 | March 10, 2011 19:23 |
Steam laval nozzle | Ahmet | FLUENT | 6 | December 26, 2009 10:26 |
superheated wet steam (avoid condensation in a nozzle) | Ralf Schmidt | Main CFD Forum | 1 | August 12, 2009 16:18 |
superheated wet steam (avoid condensation in a nozzle) | Ralf Schmidt | FLUENT | 0 | August 11, 2009 11:55 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
