Direct Optimisation warning about parameter update |
December 22, 2023, 15:44 |
Hello, the aim of my project is to find the optimum location of an impeller within a pump that produces the maximum mass flow rate for zero pressure across the pump. I ran my calculation in fluent and obtained DP0 as shown in the image 'parameters', which i am happy with. The problem is that when running direct optimisation, i am getting a warning as shown at the bottom in the image 'directopt warning'. The same message pops up shortly after for Zmovement.
For context, Xmovement and Zmovement are the movement in the x and z direction for the pump housing (so that impeller stays in its same position) and radial distance and angular distance are related to said movements as they are the polar co-ordinates. Please help Last edited by CFDstudent2010; December 22, 2023 at 18:52. |
direct optimisation |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 11:05 |
CFX problem in ubuntu (linux) | Vigneshramaero | CFX | 0 | July 13, 2012 11:22 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
