December 13, 2023, 04:14 |
Outlet pressure is not varying as expeected
Fayaz Saheer
Rep Power: 2 |
I gave inlet pressure as an expression , but the outlet pressure is not varying and giving very low outlet pressure as shown in the image
December 13, 2023, 09:30 |
Moritz Kuhn
Rep Power: 17 |
What do you expect? It looks quite feasible, if the outlet area is greater, then the inlet and even if you have an ideal gas flow.
December 13, 2023, 10:13 |
Fayaz Saheer
Rep Power: 2 |
see here the fluid is water but the outlet pressure is not varying with what the inlet value is given. It is almost the same value as the gauge pressure I gave to the outlet. I want to see the variation in outlet pressure, when the inlet pressure expression is IF(0[s]<=t<=1e-3[s], 34e7[Pa]-68e9[Pa/s]*abs(t-5e-4[s]), 0[Pa])
The flow is through a simple pipe what should I do to get the pressure variation at outlet? Thank you |
December 13, 2023, 10:18 |
Moritz Kuhn
Rep Power: 17 |
Did you try to decrease the time step and to increase the iterations per time step?
December 13, 2023, 10:20 |
Fayaz Saheer
Rep Power: 2 |
the time step is 1e-4 and iterations per time step 250 ,and should I further increase it?
December 13, 2023, 10:25 |
Moritz Kuhn
Rep Power: 17 |
Yes your pressure variation is only in 1e-3 s, so you have only 10 time steps to map the flow behavior. Try with 1e-5 s and take only 100 iterations or less (depends on the convergance)
December 13, 2023, 10:27 |
Fayaz Saheer
Rep Power: 2 |
ok thank you so much I'll try it
December 13, 2023, 10:29 |
Moritz Kuhn
Rep Power: 17 |
There you go and let me know if it helps.
December 14, 2023, 00:13 |
#9 |
Fayaz Saheer
Rep Power: 2 |
hi ,i changed the time step to 1e-5 but still there is no change , now the outlet pressure is negative
December 14, 2023, 03:17 |
#10 |
Moritz Kuhn
Rep Power: 17 |
I would say, that is a big change, with negative outlet pressure something is completly wrong. Refining the time step should always lead to better results.
December 15, 2023, 00:41 |
#11 |
Fayaz Saheer
Rep Power: 2 |
What would you say could be wrong here?
December 15, 2023, 01:03 |
#12 |
Fayaz Saheer
Rep Power: 2 |
The PS is to reduce the effect of high pulse pressure by putting in baffles, how would you recommend me to proceed from models onwards?
the inlet is of type pressure and outlet is massflow-outlet type , the model i used is k omega realizable with the timestep as you recommended. the input pressure expression is IF(0[s]<=t<2e-3[s],25e4[Pa],IF(2e-3[s]<=t<3e-3[s],33.75e7[Pa]-68e9[Pa/s]*abs(t-5e-4[s]),IF(3e-3[s]<=t<=5e-3[s],25e4[Pa], 0[Pa]))) and oulet massflow is 0.06kg/s. Thank you very much!! Last edited by fayazsaheer; December 15, 2023 at 02:13. |
December 15, 2023, 04:34 |
#13 |
Moritz Kuhn
Rep Power: 17 |
I would recommend to use a pressure outlet instead of masslfow outlet. What about the residuals?
December 15, 2023, 04:45 |
#14 |
Fayaz Saheer
Rep Power: 2 |
And what to give gauge pressure at outlet?
December 15, 2023, 04:49 |
#15 |
Moritz Kuhn
Rep Power: 17 |
Take 0, and for the inlet the pressure drop for the flow without the pressure pulse.
December 15, 2023, 04:54 |
#16 |
Fayaz Saheer
Rep Power: 2 |
The objective is to reduce the pulse
Yea this is how i did initially(outlet pressure=0[Pa]) and then i got the first graph attached above in the first post which seems too low and practically to achieve that low pressure at outlet is not possible. when i did with outlet as outflow i got the inlet and outlet pressures coincident which i am attaching below. |
December 15, 2023, 05:40 |
#17 |
Moritz Kuhn
Rep Power: 17 |
With the mass flow outlet, you set a constant pressure drop between in- and outlet. Is this realistic? With variable pressure inlet and costant pressure outlet you will have a variable massflow depeding on the pressure difference between inlet and outlet. These are completely different things. Does the solution converge?
December 15, 2023, 06:17 |
#18 |
Fayaz Saheer
Rep Power: 2 |
yes it does converge after 100 iterations, what changes would you suggest for the outlet to be approximately 1 order below inlet. thank you very much
December 15, 2023, 08:33 |
#19 |
Moritz Kuhn
Rep Power: 17 |
Set to pressure outlet (0 gauge pressure) and massflow inlet. Run the calculation in steady state. Calculate the pressure drop (via surface report). Change the inlet boudary to pressure inlet (set inlet pressure 0 + calculated pressure drop). Run the simulation in steady state. Save the data, change to transient and set your pulse pressure inlet function (you have to change the function by adding the pressure drop for the flow without pulse). It is always a good advise to start a transient calculation from a steady state solution.
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 13:23 |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 19, 2018 00:39 |
simple model, difficult outlet | Eric | CFX | 7 | May 23, 2014 09:13 |
Pressure outlet BC help! | eishinsnsayshin | FLUENT | 7 | December 4, 2012 00:36 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 13:41 |
