Issue with solid-to-porous conduction in non-equilibrium thermal model
Old   December 6, 2023, 08:47
Arrow Issue with solid-to-porous conduction in non-equilibrium thermal model
Gary Farrell
gfarrell is on a distinguished road
Hi, I am trying to use the non-equilibrium thermal model in ANSYS Fluent to study a conjugate heat transfer problem involving porous media. In my domain, I have an aluminum base layer, with a constant temperature applied to its bottom face. Above this, I have an aluminum porous region that will transfer heat to the fluid flowing over the system (see image 'domain_setup').
I only created to bodies - the base layer and the porous region. When I activate the non-equilibrium thermal model, Fluent creates an additional "solid" body in the porous region to solve the solid energy equation.
The final results however are not what we expect (see image 'thermal'). The issue I am encountering is that heat is not being properly transferred between the base layer and the solid part of the porous region. You can see from the temperature plots that there is only heat transfer to the fluid near the top surface of the base layer, i.e. there is apparently no direct heat conduction from the base layer into the "solid" part of the porous region that Fluent created. We expected the temperature of the porous region to be uniformly higher, since the inlet velocity is fairly low.
Maybe there is an issue with the interface between the base layer and the new "solid" part of the porous region?
I would greatly appreciate any help you could offer on this matter. Thank you!
gfarrell is offline   Reply With Quote
Old   April 15, 2024, 05:45
Himanshu
Himanshu_Shrivastava is on a distinguished road
Did you got any solution for this problem?
Himanshu_Shrivastava is offline   Reply With Quote
heat conduction, non-equilibrium thermal, porous media
Non-overlapping cells using non-equilibrium thermal model in porous medium coewgb FLUENT 1 May 23, 2018 02:48
Non-equilibrium thermal model for porous medium mmunige FLUENT 1 July 14, 2016 07:03
local thermal non equilibrium model in porous media adi.ptb Fluent UDF and Scheme Programming 0 November 1, 2014 16:00
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
