November 24, 2023, 16:46 |
Fluent Meshing Symmetry Help
Hello y'all,
I have problem to ask you. I had designed a combustion chamber (gas turbine anular) for my project. It has symmetry as you can imagine image-1 click image-2 click As seen, there is a symmetry with the axis of rotation as the bottom axis. Should I close the side walls? Additionally, when I close the side walls as solid, creating a "cap" is not a problem. However, I cannot create a "cap" when the side walls are open in this way. What approach should I take? Well I found out that I needed to create fluid surfaces also. Thank you everyone Last edited by devolet; November 25, 2023 at 05:58. Reason: You can delete it. Found a solution :) |
combustion chamber, fluent meshing |
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 10:49 |
Fluent Meshing Mode | elochana | FLUENT | 1 | November 24, 2020 03:34 |
Problem when opening Fluent Meshing | crinoid | FLUENT | 0 | March 11, 2019 05:39 |
[ANSYS Meshing] polyhedral mesh which is generated directly in Workbench Poly Meshing for Fluent | teguhtf | ANSYS Meshing & Geometry | 0 | January 24, 2019 23:04 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
