Quadratic element order in Fluent Mesher?
Old   November 22, 2023, 18:36
Default Quadratic element order in Fluent Mesher?
CFD_Mike is on a distinguished road
On Ansys mesher there is an option to create quadratic elements. Does this option exist in the Fluent Mesher? I've looked through the fluent user guide and the text command list. I couldn't find any mention of quadratic or second order meshes.
CFD_Mike is offline   Reply With Quote
Old   November 23, 2023, 00:53
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
not sure about direct implementation, but you may try to adapt your mesh in the region of interest, that would literally double number of nodes in that region (boundary or whatever)
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 23, 2023, 16:56
Thanks for the suggestion. I'd still like to know if there is a direct implementation.
Old   December 12, 2023, 22:29
polinkuer12 is on a distinguished road
not sure about direct implementation, but you may try to adapt your mesh in the region of interest, that would literally double number of nodes in that region Quick Draw
I wonder how to adjust it to make it more suitable?
polinkuer12 is offline   Reply With Quote
elements, fluent mesher, mesh, quadratic, seocond order
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 10, 2022 00:58
[General] Problem with reading in multiple grouped Ensight .case files into paraview scro1022 ParaView 0 November 27, 2020 09:00
Order of element vs Degrees of freedom of the element granzer Main CFD Forum 5 July 13, 2019 05:40
Software to mesh using high order element with unevenly spaced interpolation node lzhaok6 Mesh Generation & Pre-Processing 4 August 14, 2016 01:01
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
